Activity › Forums › Adobe After Effects › accidental masking with Selection Tool
  • accidental masking with Selection Tool
    Posted by Bob Cole on February 14, 2016 at 12:44 am
    I have a layer selected. I have the Selection Tool activated. I try to move the layer in the comp window, but instead of an arrow, I have a crosshair, and I start drawing a mask. The mask is applied to the comp itself, not a layer. Once I have “drawn” this mask, I can move the layers at will, but I have to expand the mask to the entire comp in order to access the layers.
    I know that I must have made some change to make this happen but I have not been able to find the toggle.
    Your advice is most appreciated.
    Bob C
    Kalleheikki Kannisto replied 10 years, 7 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    February 14, 2016 at 10:18 am
    Sounds suspiciously like a program error. Does the problem persist if you close and open the program?
  • Bob Cole
    February 14, 2016 at 12:25 pm
    Not only did I close, restart, re-open AE, but I tried two different versions of AE with the same result.
    February 15, 2016 at 8:24 am
    Ok, it must be the region of interest tool then. The icon between the comp resolution and toggle transparency grid. Turn that off.
