Accidental H.246 native edit – project done – export .mov freezes near end
Im not sure if my last one got posted on this thread but ill repeat:
I did the same thing i was stupid and totallyforgot to convert to prores. I shot with a 7d and imported the footage into fcp. I edited the entire project and exported it using just the current sequence settings which typically fcp auto sets based on the video you bring in. After the export i watched my .mov file in QT and the video plays fine until near the end it will freeze on a video frame but the audio plays thriugh. Its somewhat weird because my video goes black like it should bc i edited it like that then it is supposed to come back up to a clip and the. After 3 seconds i have the clip freeze also on purpose i was doing credits. Problem is that the first part of the vid doesnt play it just is black then hits the freeze frame and goes black again. Its nothin with the clips on my timeline. Thise are set up fine. But i wanted to be thorough and im sure thats confusing. But to simplify the exported .mov file will skip and freeze near the end the rest of the vid plays fine. I need to fix this somehow and then load it to youtube. Does anyone know what i can do or what the problem is. Im thinking it has skmething to do with the fact that my dumb ass forgot to convert to prores but maybe its something else. I need help asap if anyone can!! Thanks!!
