Activity › Forums › Apple Final Cut Pro Legacy › Accidental FCP 6 upgrade
  • Accidental FCP 6 upgrade
    Posted by Max Frank on June 11, 2007 at 11:19 am
    I wanted to just upgrade to Motion 3, but for some reason, FCP 6
    was also accidentally upgraded and I would much rather remain in FCP 5.
    What’s the best way to revert to FCP 5.1.2?
    Wayne
    John Christie replied 19 years, 3 months ago 5 Members · 6 Replies
  • Jerry Hofmann
    June 11, 2007 at 11:28 am
    I don’t think you can run Motion 3’s projects in FCP 5… That’s why it installed it. Why not run FCP 6? It’s a pretty stable piece of software actually.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Max Frank
    June 11, 2007 at 12:04 pm
    I didn’t want to upgrade yet, because the rest of my team haven’t
    yet upgraded, and now we can’t share files.
    Also, FCP 6 won’t open a large [257MB] project (that FCP 5.1.2
    opened easily)
    I didn’t clone my hard-drive and do a clean install of the OS, etc
    [as is recommended] because all I wanted was Motion 3, and not the
    whole package.
    Now what should I do??
    Any advice from the sages?
    W
  • Steve Eisen
    June 11, 2007 at 1:00 pm
    What do you think you need to do? There is no magic that will make FCP 6 and Motion 3 dissapear from your system.
    You are going to have to do a fresh instal of 5.12.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Max Frank
    June 11, 2007 at 1:18 pm
    yeah, I figured that’s what I’m going to have to do.
    Or… get the entire team to upgrade! [Which is probably
    more likely].
    W
  • Bret Williams
    June 11, 2007 at 1:42 pm
    I’m running both. I kept 5.1.4 on my system. I hid it from the installer by putting a copy on an external drive and unmounting it.
    I would figure you can just copy the app from one of your other systems, rename it Final Cut Pro 5 and copy it to your FCP 6 system and it will most likely run just fine. Give it a shot.
  • John Christie
    June 17, 2007 at 7:41 pm
    Bret
    I’m planning on doing what you did, archive FCP 5.14 to another drive before updating to FCP 6. Have you seen any of the media manager issues in 6 that others have reported?
    Cheers
    John Christie
    Keyframes Editing
