Activity Forums Blackmagic Cameras Accessories for Blackmagic Production Camera 4K
  • Accessories for Blackmagic Production Camera 4K
    Posted by Prathvish Hegde on April 28, 2014 at 7:16 am
    hi,
    i have purchased 4k camera and want some insight into what are best(average price) and most needed set of accessories i should purchase inorder to shoot a film with the camera.
    sorry if this is a repeat question please bear with me for my little knowledge.(i should be knowing it after ten years as a colorist?????)
    prathvish hegde
    colorist
    (DaVinci Resolve and 2Kplus)
    https://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
    Randy Wiliams replied 12 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • Nikolas Bäurle
    April 30, 2014 at 1:02 am
    Probably the most important one of all is external power. Pro X sells a 2m d-link to bmcc adapter cable for 60 euros. so you can connect it to v-mount batteries. Roko also sells a short one for 15 euros
    Lanparte has some very good and lower-priced rigs. for a basic rig you will be spending about 500 euros and the full bmcc rig costs about 2700. There a many options and configurations. Sunrise also has some cheap good quality rigs
    You will need: (in euros)
    – rig and/or cage (starting at 200 for basic)
    – Adapter cable and V-mount batteries (15 – 60 for cable, batteries start at 200)
    – V-mount battery charger (120 for a d-link charger from Beillen)
    – V-mount mounting plate to connect to rig ( 200 )
    – a matte box with filters (500 + at least 100 per filter) or at an nd fader (100-300)
    – a follow focus (starting at 200)
    for sunny and even cloudy days outside:
    – a screen hood (like the HBM1 from Hoodman for 100 bucks)
    or an electronic viewfinder like the one from Cineroid for 700
    “Always look on the bright side of life” – Monty Python
  • Deleted User
    April 30, 2014 at 7:36 pm
    There are literally thousands of accessory items you might use with a BMPC-4K. Most accessories are the same you’d use with many professional video cameras. Many needn’t be specifically designed for use with the BMPC-4K. In fact, it can be advantageous to own accessories that are compatible with a variety of cameras, now and in the future.
    Dealers such as B&H in NYC sell many popular accessories compatible with BMPC-4K and other cameras. Even if you don’t buy from B&H, their extensive catalog can be a good starting point for your research:
    https://www.bhphotovideo.com
    FYI: Here are some of the accessories I’m using or considering using with my BMPC-4K and other cameras:
    https://herefortheweather.wordpress.com/2013/03/04/bmcc-rigged-thinking/
    See also:
    https://herefortheweather.wordpress.com/2014/02/21/bmpc-4k-shooting-tips-from-early-users/
  • Prathvish Hegde
    May 2, 2014 at 2:01 pm
    thank you will go through the B&H list.
    i have ordered the below ones is anyone using these???
    sandisk extreme 2 ssd (240gb)
    Globalmediapro Li190S Lithium ion Battery 190WH
    ePhotoInc Top Handle Camera Cage For Black Magic Camera Video Movie Camera Follow Focus BMC-M
    Opteka CXS-300 Dual-Grip Video Shoulder Stabilizer Support System for DSLR Cameras & Camcorders.
    please let me know the best set of IR and ND for the BMPC 4k .
    what do you think about the holymantra variable nd filter???
    what is your opinion on Lanparte V-Mount Battery Pinch??
    please suggest a good Tripod,mic and recorder .
    prathvish hegde
    colorist
  • Deleted User
    May 2, 2014 at 5:12 pm
    [prathvish hegde] “… please let me know the best set of IR and ND for the BMPC 4k …”
    Already answered in item #11 in the link I provided in my previous post:
    I use a “Hoya UV IR cut filter” (77mm):
    https://www.bhphotovideo.com/c/product/857393-REG/Hoya_A77UVIR_77_mm_UV_and.html
    Also, “sandisk extreme 2 ssd (240gb)” are not on Blackmagic’s recommended SSD list. I use “Kingston 240 GB HyperX 3K (SH103S3/240G)”. See:
    https://www.blackmagicdesign.com/support/detail/faqs?sid=27541&pid=34851&os=mac
    https://www.peterdv.com
    Blog: https://herefortheweather.wordpress.com
  • Prathvish Hegde
    May 5, 2014 at 7:17 am
    thank you peter will go through the links.
    prathvish hegde
    colorist
  • Prathvish Hegde
    May 5, 2014 at 7:27 am
    whats your view on Singh ray Vari-N-Duo in Standard Ring Mount are the available?
    prathvish hegde
    colorist
  • Richard Martz
    May 9, 2014 at 7:14 pm
    This was my list from a few months ago. Prices are less now. My advice is to skip the vmount battery system and get a battery with an integrated rail block. This is less expensive in the long run and won’t have to mount right behind your viewfinder. My company manufacturers these batteries. Tough as nails: https://www.ebay.com/itm/221399060449?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    My accessories list:
    Here were the essential items that I knew I needed to fully exploit the camera along with my very modest accessory budget (IN US DOLLARS:
    Camera – $2000
    Lenses – $3000 (This line item could easily have been tens of thousands of dollars)
    Rail Mounting System – $300
    Two BrikPower Batteries 5 Amp Hour – $450
    Charger – $110
    Zoom H4N audio recorder – $200
    Matte box – $500
    Cage system with handle – $400
    2, Sandisk Extreme 480GB – $500
    So the basic cost is around $7460
    At the encouragement of Marco Solorio I managed to shave off about $2200 off the cost of implementing the camera.
    But I did not include the $4000 of 4×4 filters I already own. You may choose not to use filters and rely on the effects within your NLE to achieve your own cinematic look. Your requirements will be a bit different but I thought the people who are considering a BMCC purchase should consider the TOTAL cost as they approach the purchase.
    Sincerely,
    Richard Martz
    MagicMartz Media, Inc.
    BrikPower Batteries
    Atlanta, GA
    FCP 7
    FCP X
    Blackmagic Cinema Camera
    ADOBE CREATIVE SUITE CC
    Premiere Pro
    DaVinci Resolve 9.0
    MAC 8 core w 32GB memory
    After Effects
    PhotoShop
    Illustrator
    Sony HD Cameras
    24′ Camera Crane with Motorhead
    8′ jib arm
    20K watts of lighting
    Multitrack audio
    Teleprompters
    Grip Truck/trailer
    Location video monitoring
    Door and hood mounts
    Lots of other Fun Stuff!
  • Randy Wiliams
    August 13, 2014 at 10:35 am
    There are lot of accessories not only for blackmagic camera but also for other camera. Technology have really made our work very easy and professional. Different equipment and accessories have been invented which have made our blackmagic camera A BIG Camera or setup.
    We can use following tools
    Lenses
    Battery and power options
    Memory Card
    Cage
    Shoulder rig with matte box and follow focus
    Camera bag
    These are few accessories which one should have with blackmagic camera.Check following links, definitely you will get some helpful information
    https://www.bhphotovideo.com/explora/video/hands-reviews/blackmagic-design-digital-cinema-cameras-and-accessories
    I am having following accessories
    Sandisk memory card
    Camtree hunt shoulder mount; matte box, follow focus are also included. And A box and power cable was free with it.
    https://www.thecinecity.com/eshop/CAMTREE-HUNT-CH1-BMC-EX-BLACK-MAGIC-CAMERA-RIG-KIT.html
    Cineroid Viewfinder
    Monitor
    https://www.thecinecity.com/eshop/Proaim-Pro-LCD-003-7-monitor-kit.html
    Rain Cover
    https://www.thecinecity.com/eshop/CAMTREE-Rain-Cover-Wetsuit-for-BlackMagic-Cinema-Camera-and-Production-Camera-4K-RC-BMC.html
