Activity Forums Adobe After Effects Expressions Accessing second layer parameter from script
  • Accessing second layer parameter from script
    Posted by Shanat Kol on September 25, 2018 at 4:52 pm
    Hello, so I am looking into using script to modify the second parameter of a layer information. (outlined in red in the screenshot).
    So far I have this code:
    selectedLayers[i].property(“Effects”).property(“MyEffect”).property(1).SetValue(1);
    which allow me to set the first parameter to the layer I want but I can’t figure out how to modify the second one…
    I need to set it automatically, because if the user keeps that parameter to Source (and not mask) the mask outline doesnt update unless a purge or another change happens, whereas it’s realtime when set to mask…). So I want to force it to Mask ☺
    Anyone knows it if’s possible to do that?
    Thank you very much!
    Shanat Kol replied 7 years, 11 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 25, 2018 at 8:24 pm
    I don’t see any way to access it.
    Dan
  • James Ronan
    September 25, 2018 at 8:41 pm
    Yeah as Dan says I don’t think you can. but you could try saving a preset (.ffx) with it already set to Mask, and add that instead.
  • Shanat Kol
    September 26, 2018 at 5:34 am
    That’s pretty much what I had gathered, but I thought I might have been missing something.
    Thank you for confirming and for your help!
