Activity Forums Sony Cameras Accessing MXF Files
  • Accessing MXF Files
    Posted by Derek Hader on January 28, 2009 at 12:18 am
    Hello,
    I’m not fluent with this but, here’s my best explanation. I have a PDW-F350. Typically to load my MXF files using my PDW-U1 onto my PC (XP) for use in PPro CS3, I could do 1 of 2 things. 1 – Copy and drag the MXF clips from My Computer\XDCAM\Clip\C0001.mxf (or something similar) to my storage drive. 2 – It usually worked using the PDZ-1 application.
    I had to recently reinstall everything on my PC. I’ve downloaded the firmware and drivers (includining PDW-U1 Version 2.10) etc, I thought i had downloaded before to make all this work. I have PDZ-1 installed. But not PDZ-1 does not recogize the Disk, and when i try the drag and drop method, the folder stucture on the disk now is much different.
    Whereas before I would go: My Computer\XDCAM\Clip\C0001.mxf
    Now it seems: My Computer\PROAV\CLPR\C0001\….mxf
    But now, instead of all my MXF files being in one directory, each clip is separated into its own folder, and there are 6 MXF files… 4 audio track MXF files, 1 video track MXF, and the low-res (proxie?) MXF file that contains both V+A. Also, it doesn’t work now to import them into Premier.
    At first I thought I had accidently changed a setting on the camera to produce separate video and audio files. But I’ve checked old disks that i know imported properly in past, and ruled out camera settings.
    so i guess i must have the wrong software/firmware/driver(s)???
    Help and advice greatly appreciated!
    -Derek
    Derek Hader replied 17 years, 7 months ago 2 Members · 2 Replies
  • Robert Dexter
    January 29, 2009 at 9:24 am
    It sounds like you may be just missing the XDCAM Drive Software that makes the PDW-U1 look just like one of the decks or camcorders (i.e. /Clip/C0001.MXF, etc. rather than /PROAV/CLPR/C0001/C0001V01.MXF, etc.).
    Try e.g. https://servicesplus.us.sony.biz/sony-software-model-PDWU1.aspx.
  • Derek Hader
    January 29, 2009 at 5:25 pm
    Thanks, but I’ve gone thru-out that site and downloaded and tried everything there i could think of, but nothing so far has worked.
    I’ve tested my pdw-u1 on another computer here and this is the folder structure i see:
    G:\Clip\C0001.mxf ; C0001m01.xml ; C0002.mxf ; etc, ect
    G:\Edit\(empty folder)
    G:\General\(empty folder)
    G:\Sub\C0001s01.mxf ; etc, etc
    (hidden folder)G:\PROAV\CLPR\C0001\C0001A01.mxf;C0001A02.mxf; and other files for each track in C0001. then theres a folder for each clip (G:\PROAV\CLPR\C0002,3,4,5,etc, etc)
    G:\PROAV\EDTR (empty folder)
    This folder heirarchy works for me. I take the MXF files from G:\Clip\ and import them directly in premier audio and video together in 1 file, and have no problems.
    On my computer where I’m having the problems, this is my folder structure:
    G:\PROAV\CLPR\C0001\C0001A01.mxf;C0001A02.mxf; and other files for each track in C0001. then theres a folder for each clip(G:\PROAV\CLPR\C0002,3,4,5,etc, etc)
    In the add/remove programs option in my control panel, I’ve figured out which versions are installed on the working computer:
    – Sony XDCAM Drive Software V 1.0.0.68
    – Sony XDCAM Viewer V 2.11.0139
    – ProDisc V 2.040
    – PDZ-1 V 2.23.00
    I’ve successfully downloaded and installed newer versions of all 4 of these on my computer, but to no avail. I’ve tried to locate the exact same versions to try to re-create the properly working conditions, but cannot find them online anymore.
    If you don’t know, can you please tell me what works for you if u have a similar set-up.
    Thanks again,
    -D
