Accessing Layerset via Xpresso
In advance thank you for any help you could provide
2 projection cameras, 2 PSD files, many layers, Does anyone know how to access Layerset via Expresso to change the projected layers? or another way to streamline the process
Right now I have to go into each texture, into the color channel, click the image icon, then click on layer set and select the layer I need to use. I have to do this for the rib and the alpha. I have about 30 layer en inch psd, and then I have to do 3 different versions so as you can see it is a lot of projected images/layers, I need to figure out a way to change them in a timely manner.
Again thanks
Juan Obregon
