Activity Forums Adobe After Effects accessing camera expression
  • accessing camera expression
    Posted by Daniel Tegeland on May 12, 2011 at 7:22 am
    Hi!
    I have used an expresion line to acces the active camera heavily(below). I you would like to use a specific camera instead of the active one. How would you go about that? thanks
    thisComp.activeCamera.toWorld
    Walter Soyka replied 15 years, 4 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    May 12, 2011 at 7:44 am
    This post should be in the expressions forum – better chances to get a quick answer.
    https://forums.creativecow.net/adobe_after_effects_expressions
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Daniel Tegeland
    May 12, 2011 at 7:51 am
    thanks!
  • Walter Soyka
    May 12, 2011 at 11:53 am
    Cameras work just like layers.
    Instead of using thisComp.activeCamera, you can pick-whip another camera layer, or directly enter something like this:
    thisComp.layer("Camera 2")
    If you refer to the camera more than once in your expresion, you can clean up your code a bit as follows:
    c = thisComp.layer("Camera 2");
    c.toWorld([0,0,0]);
    Walter Soyka
