Activity Forums Avid Media Composer Access Violation on Video Display Setting
  • Access Violation on Video Display Setting
    Posted by Sal Fabbri on July 7, 2005 at 2:06 am
    Hi, I edit on an Avid Xpress Pro system on a PC. I recently bought the Canopus ADVC 110 video converter to capture from analog souces and to preview on an NTSC TV. All my hardware is hooked up correctly, but I can not get a signal from the Avid to the TV.
    My problem arises when I go to change the video display. When I try to open the setting, I get “an ACCESS_VIOLATION exception occurred. For more info. see error log….” I open the error log that reads, “AVID SYSTEM DUMP – Wed Jul 06 21:56:19 2005 (and it goes on to list my system specs.)” Then, If I try to open the timeline settings right after, I get a “FATAL ERROR, msg:Refcon is not an AWindow…”
    Any help on this matter would be much appreciated.
    Sal.
    Sal Fabbri replied 21 years, 1 month ago 1 Member · 1 Reply
  • Sal Fabbri
    July 7, 2005 at 9:18 pm
    My buddy gave me a hand.. turns out that there is a switch on the Avid timeline to toggle between video out. Blue sends a singal to the monitor and green is for editing/compositing/colour correcting/renders/etc.
    …in case somebody else has the same issue.
