Activity Forums Adobe After Effects Expressions Access to the time and the duration of value.
  • Access to the time and the duration of value.
    Posted by Benoit Kergosien on June 21, 2014 at 9:28 pm
    Hi there,
    despite a hunt of expressions in the forum ( thank you dear Dan Ebberts)
    I can’t achieve to access the duration of a value.
    The short story:
    My SQUARE is moving withtwo arrows on left and right side, i want their animations switch to on when the SQUARE moves in their direction
    and when it changes in the opposite the arrows scale down in 2 seconds and the opposite arrow switch to on,etc…
    No doubts that many parts of my following process is unificient so please correct me.
    The long story:
    A SQUARE is animated with a wiggle:
    seedRandom(1);
    freq = 0.2;
    amp = 300
    loopTime = 5;
    t = time % loopTime;
    wiggle1 = wiggle(freq, amp, 1, 0.5, t);
    wiggle2 = wiggle(freq, amp, 1, 0.5, t - loopTime);
    ease(t, 0, loopTime, wiggle1, wiggle2)
    Two slider control are applied to the square with an
    expression to determine changes in the direction of the SQUARE.
    Slider DIRECTION:
    delta = thisComp.frameDuration;
    tolerance = 0.7;
    mySquare=thisComp.layer("SQUARE");
    v1 = mySquare.position.velocity;
    angle1 = Math.atan2(v1[1],v1[0]);
    v2 = mySquare.position.velocityAtTime(time-delta);
    angle2 = Math.atan2(v2[1],v2[0]);
    if (Math.abs(angle1 - angle2) > tolerance) 0 else 100;
    Slider NUMBER:
    threshold=100;
    direction= effect("DIRECTION")("Slider");
    above = false;
    frame = Math.round(time / thisComp.frameDuration);
    n = 0;
    while (frame >= 0){
    t = frame * thisComp.frameDuration;
    if (above){
    if (direction.valueAtTime(t) < threshold){
    above = false;
    }else if (direction.valueAtTime(t) >= threshold){
    above = true;
    n++;
    frame--
    n
    Two Compositions: Left Arrow and Rigth Arrow are parented to the SQUARE.
    I want the Arrow scale in 0 to 20 when the direction changes for the first time
    then scale out 20 to 0 with a decay of 2 seconds when the direction changes again and so on.
    But I don’t achieve to determine the time of this change in the direction.
    In addition when the direction occurs i would remap the time to synchronize the Arrow’s animation
    (depending wether the direction goes to the left or to the right)
    At the moment i accomplish that with an expression on the Time Remap:
    Left Arrow:
    number=thisComp.layer("SQUARE").effect("NUMBER")("Slider");
    i=number%2;
    if (i==0)
    {0}
    else
    {1};
    Right Arrow:
    i=number%2;
    if (i==0)
    {1}
    else
    {0};
    But once again i dunno how to access to the time and the duration of direction changes for example between the 4th and the 5th
    of my slider “NUMBER”. My Arrow animation stays fixed. 🙁
    I join the project if someone wants to take a look it would be easier to understand.
    7655_squaredirection.aep.zip
    Any help would be gladly apreciated. Thanks in advance.
    Benoit Kergosien
    Benoit Kergosien replied 12 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 21, 2014 at 10:51 pm
    For the direction, I think you just need to monitor the x component of the square layer’s velocity:
    mySquare.position.velocityAtTime(t)[0]
    if it’s positive, the square is/was moving to the right, negative to the left.
    From there it gets complicated, even if you make the simplifying assumption that the scale-up and scale-down animations are never triggered while the other animation is in progress. You need a more complicated threshold detector that starts at the current frame and goes backwards to find the most recent threshold crossing (in either direction). Whether it was a positive-to-negative or negative-to-positive transition determines whether you run the scale-up or scale-down animation (you would do the opposite for the other arrow).
    Anyway, tricky, but not impossible.
    Dan
  • Benoit Kergosien
    June 21, 2014 at 11:45 pm
    Hey Dan!
    Thanks for your consideration.
    I simplify my code as you suggest but for the complicated treshold i’m a bit overwhelmed. I understand what you point but to transform the idea into an expression I’m afraid that I need more help.
    I updated my project file if you have time to take a look.
    7656_squaredirectionv2.aep.zip
    Benoit
