Activity Forums Adobe After Effects Expressions Access to metadata of the resulting path of a Wiggle Path object?
  • Access to metadata of the resulting path of a Wiggle Path object?
    Posted by Seymour Frost on September 17, 2021 at 1:02 am
    Hi! I don’t have high hopes that this is actually possible, but I thought this is a good place to ask:
    I have a path that I have applied a Wiggle Path effect to and I have an object that I want to animate along the resulting wiggled path. Since the path still only has those original points in its path metadata, any use of things like pointOnPath() is useless. Is there a way to access the points of the wiggled path?
    Thanks in advance!
    Seymour Frost replied 5 years ago 1 Member · 0 Replies
  • 0 Replies
