Activity › Forums › Adobe Premiere Pro › Access to color bar file in PPRO?
  • Access to color bar file in PPRO?
    Posted by Jan Janowski on September 13, 2018 at 6:54 pm
    I have posted a few times. Never got an answer.
    I would to create a color bar file where in the center
    of the white flag I add a whiter than white area of pixels
    that increase from 235 one pixel at a time to 255, then
    step back down to 235 again. On waveform monitor
    This would look like: _____/\______ with the flat area
    being 235 and the tip of the /\ being 255.
    This would be useful in verifying that there are no
    white clips in the path. The Color Bar signal already
    has “Pludges” in the black area, which will show black clipping
    but the white area does not have such parameters.
    I have created a Bars with a square of 255 (Which
    ____
    looks like this on waveform monitor: _____| |_____
    But I am striving for a more elegant solution.
    I have done this is proms before, where you
    Are at the pixel level.. but I’m at a loss on how to proceed.
    Obviously this has to be in YUV, opposed to RGB space.
    I had two Photoshop Pros attempt it and fail because
    Photoshop is RGB space.
    So Premiere Pro is an obvious choice.
    Can someone explain if this can be done, and point and
    start me in the right direction???
    Thanks.
    Greg Janza replied 8 years ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Wright
    September 13, 2018 at 9:10 pm
    well 1 pixel at a time is 255-235 or 20 pixels. so make a gradient with 20 pixels. would be easier in photoshop.
    here’s a long thread how to do it
    https://forums.adobe.com/thread/921034
  • Jan Janowski
    September 13, 2018 at 11:18 pm
    Please double check me:
    From what I gather fron the link —- I make a one
    layer grid 39 pixels wide. In Photoshop. (Like I did in an eprom
    But in hex)
    layout as follows:
    236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247,
    248, 249, 250, 251, 252, 253, 254, 255, 254, 253, 252, 251,
    250, 249, 248, 247, 246, 245, 244, 243, 242, 241,240, 239,
    238, 237, 236
    That gives me a ramp up & down.
    I don’t know how to do this in Premiere. I don’t think
    This will be correct in Photoshop.
    Every time I export a maximum white bkgnd
    in Photoshop it shows 255 in Photoshop, but imported
    into Premiere it shows up as the same amplitude as existing
    white flag Premiere’s bars—-235! Another way of saying this
    is: Photoshop 255? Imported into Premiere is 100 IRE on scope.
    The two Photoshop people I approached to help on this both
    couldn’t do it. Without having the ramp go downward from 235,
    and not upward from 235 toward 255.
    I default to others in Photoshop because I’m not very good at it.
  • Trevor Asquerthian
    September 14, 2018 at 5:26 am
    I believe that PP assumes still images (and video codecs like Animation) are 0-255 and thus maps them to 16-235 to fit 709 legal range. Try creating a 2 frame animation in photoshop (both identical) and export as full range to a codec that PP will assume is legal 709 (Dnx/ProRes).
    https://www.dropbox.com/s/aj2mn7ta79pfy8o/2_field_QT%20DNX185%20709.mxf?dl=0
    I think has 0-255 range (can’t check ATM) in DNX codec
    September 14, 2018 at 5:30 am
    https://www.dropbox.com/s/g3pj0uqoi0htbuw/2%20field%20BARS_import%20as%20709%20to%20get%20full%20range.tif?dl=0
    Is the original file as a Tiff – which imports as 16-235 in PP (from memory, not at machine atm). I put this in an AE comp & exported as DNX, flagged as 709 I think
  • Jan Janowski
    September 14, 2018 at 10:04 am
    The Tiff you gave me is limited to 16/235
    And I tried opening the mxf by importing in PPRO or PS-64 (CS6 here) without success…
    Later on today I’ll send you what I created so you can see it in PPRO There…
  • Jan Janowski
    September 16, 2018 at 8:06 pm
    I’m just nosy if anyone tried what I posted and got same results as I did?
  • Greg Janza
    September 16, 2018 at 9:18 pm
    I imported the dropbox dnx file and it is 0-255 and I imported a pure white PS file and it also imports into Premiere at 255.
    Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
    Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
