Activity Forums Adobe After Effects Expressions Access to all the properties of a layer SCRIPTING
  • Access to all the properties of a layer SCRIPTING
    Posted by Rainier Raydán on November 15, 2017 at 7:48 pm
    Hi!
    I’m wondering. Is there a way to do a for loop for all the properties of a layer? I need to access to all the properties that has values so I can modify them with a function.
    Dan Ebberts replied 8 years, 10 months ago 2 Members · 5 Replies
  • Dan Ebberts
    November 15, 2017 at 9:00 pm
    It’s complicated. You’d start with the layer, and for each of the top level properties, you’d do a recursive dive through the property heirarchy, checking each property to see if has properties, checking those, etc. You might run into properties that have a value type of CUSTOM_VALUE though, which you won’t be able to modify.
    Dan
  • Rainier Raydán
    November 15, 2017 at 9:03 pm
    Yep, I see that… ussually I do a lot of for loops diving in the diferents levels of properties. Do you know how many for loops do I need to do to make it all the way down?
  • Dan Ebberts
    November 15, 2017 at 9:40 pm
    The number of nesting levels varies, especially when you’re dealing with, for example, shape layers. You just need to call your property processing function recursively, until the property you’re processing has no properties itself.
    Dan
  • Rainier Raydán
    November 19, 2017 at 7:48 pm
    I’ve been thinking in a way to write , like you said, a property processing function but I havent find a way… can you help me with that?
    Also, I’m having troubles with the hidden properties, in this case it’s only TimeRemap. I get an error that said the property is hidden and I cant call addKey() function… You know a way to prevent this to happeng?
    Thanks a lot
  • Dan Ebberts
    November 19, 2017 at 10:01 pm
    This is a simple, recursive property sniffer (be prepared though, I get 135 properties for a simple solid):
    function processProperty(theProp){
    if (theProp.propertyType == PropertyType.PROPERTY){
    $.writeln(theProp.name);
    }else{ // must be a group
    for (var i = 1; i <= theProp.numProperties; i++){
    processProperty(theProp.property(i));
    var myLayer = app.project.activeItem.layer(1);
    processProperty(myLayer);
    You should be able to trap errors with try/catch.
    Dan
