Activity Forums Adobe After Effects Expressions Access string without quotes
  • Access string without quotes
    Posted by Steve Sierra on April 14, 2017 at 5:08 am
    I need to get a comp name and put it in an expression via scripting.
    The problem is that the comp name seems to be given with double quotes, and, as far as I know, expressions via scripting require simple quotes…
    I can work around the problem by renaming the comp, but I’d prefer leaving it as is, in case it is referenced in another expression.
    I tried changing the name for my script then re-changing it back at the end + applying autoFixExpressions, but it didn’t work.
    Thanks !;)
    Steve Sierra replied 9 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 14, 2017 at 6:47 am
    If you want to include double quotes in the expression, you can wrap the expression in single quotes in the script. For example:
    var myExpr = ‘comp(“Comp 1”).layer(“Layer 1”).transform.position’;
    Dan
  • Steve Sierra
    April 14, 2017 at 8:20 am
    Great !
    Thanks again Dan 😉
