Activity Forums Adobe After Effects Expressions access info inbetween two keyframes
  • access info inbetween two keyframes
    Posted by Bert Brown on August 22, 2008 at 6:46 pm
    I’m trigger an action to a marker and have this so far:
    p3X = position.key(3).value[0];
    p3Y = position.key(3).value[1];
    p3Z = position.key(3).value[2];
    p4X = position.key(4).value[0];
    p4Y = position.key(4).value[1];
    p4Z = position.key(4).value[2];
    p3 = [p3X, p3Y, p3Z];
    p4 = [p4X, p4Y, p4Z];
    D = .534; //duration
    mT = thisComp.layer(“MarkerControl”).marker.key(2).time;
    endT = mT+D;
    if (time>=mT) {linear(time, mT, endT, p3, p4)}
    else {value}
    the problem is the action of the keyframes actually has a manually adjusted bezier curve on it (you know, using the little handles)
    how can i access what is happening in the position info within EACH frame in between? some sort of valueAtTime perhaps?
    peep my over-the-interweb band, red abbott.
    “we electro-rock over long distances…”
    Bert Brown replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
