Activity Forums Adobe After Effects Expressions Access each Shape layer group with a specific name
  • Access each Shape layer group with a specific name
    Posted by Reuben Lara on September 28, 2019 at 11:16 pm
    Hey all!
    I am able to add an effect (in this case, Trim Paths) to the contents of a specific shape layer group named “path”. But when there is more than one group with the same name, it only targets the last one. Is there a way to loop through all of them individually? Here’s my setup:
    13760_screenshot20190928at7.03.52pm.png.zip
    This code works for one instance of “path” group:
    var mySelection = app.project.activeItem.selectedLayers;
    for (var i=0; i <mySelection.length; i++){
    mySelection[i].property("Contents").property("path").property("Contents").addProperty("ADBE Vector Filter - Trim");
    Trying to load all the groups named “path” into a variable and loop it, with no success:
    for (var i=0; i<mySelection.length; i++){
    var pathGroup = mySelection[i].property("Contents").property("path");
    for (var n=0; n<pathGroup.length; n++){
    var trimPaths = pathGroup[n].property("Contents").addProperty("ADBE Vector Filter - Trim");
    Any ideas? Thanks!
    Reuben Lara replied 6 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 29, 2019 at 6:24 pm
    I’m not sure exactly how you have things set up, but in general I think you could do something like this:
    var n = mySelection[i].property("Contents").numProperties;
    for (var j = 1; j <= n; j++){
    if (mySelection[i].property("Contents").property(j).name == "path"){
    // do stuff
    Dan
  • Reuben Lara
    September 29, 2019 at 11:43 pm
    That was it, thanks so much! (And thank you for being some kind of omnipresent scripting genie that has helped so many people over the years… much appreciated!)
    Reuben
