Activity Forums Adobe After Effects Expressions Acces X and Y values of vertices seperately ?
  • Acces X and Y values of vertices seperately ?
    Posted by Steve Sierra on May 1, 2017 at 5:55 am
    For a script I am working on, I want to duplicate and reduce my mask shape multiple times.
    So I need to know where my Mask shape vertices are compared to my Layer’s half width and height (if the verts are in the top/left, top/right, bottom left or bottom right quarters of myLayer) in order to push them in.
    To do that, I would need to compare the x value of each vertice with the layer’s half width and it’s Y value with the layer’s half height in a for loop…
    Could anyone tell me how to do this ?
    Thanks in advance !
    Steve Sierra replied 9 years, 4 months ago 2 Members · 3 Replies
  • Dan Ebberts
    May 1, 2017 at 6:12 am
    If you know the coordinates of the center, you should be able to figure out which quadrant a given vertex (v) is in with something like this:
    center = ???
    if (v[0] < center[0]){
    if (v[1] < center[1]){
    // upper left
    }else{
    // lower left
    }else{
    // upper right
    }else{
    // lower right
    Dan
  • Steve Sierra
    May 1, 2017 at 9:58 am
    Hi Dan,
    Thanks for your quick reply !
    That’s exactly what I am trying to do… The problem is, isn’t v[0] the first vertex of the shape, v[1] the second, etc…
    I don’t know how to get to “v[0].value[0]” or “v[0].value[1]”.
    Here’s what I’m doing :
    var origLayer = app.project.activeItem.selectedLayer[0];
    var origHalfX = origLayer.width/2;
    var origHalfY = origLayer.height/2;
    var origShape = origLayer.property(“ADBE Mask Parade”).property(“ADBE Mask Atom”).property(“ADBE Mask Shape”).value;
    var origVerts = origShape.vertices;
    for(var i = 0; i< numZLayers; i++){
    var copyLayer = origLayer.duplicate();
    var copyShape = copyLayer.property(“ADBE Mask Parade”).property(“ADBE Mask Atom”).property(“ADBE Mask Shape”).value
    var modifiedShape = origShape;
    var modifiedVerts = modifiedShape.vertices;
    var h = origHalfX * (i/numZLayers);
    var v = origHalfY * (i/numZLayers);
    for(var j = 0; j < origVerts.length; j++){
    var Overt = origVerts[j];
    var Mvert = modifiedVerts[j];
    var OvertX = Overt[0];
    var OvertY = Overt[1];
    if(OvertX < origHalfX && OvertY < origHalfY){origVertsM[j] = [OvertX + h, OvertY + v]};
    if(OvertX < origHalfX && OvertY > origHalfY){origVertsM[j] = [OvertX + h, OvertY – v]};
    if(OvertX > origHalfX && OvertY < origHalfY){origVertsM[j] = [OvertX – h, OvertY + v]};
    if(OvertX > origHalfX && OvertY > origHalfY){origVertsM[j] = [OvertX – h, OvertY – v]};
    copyShape = modifiedShape;
    Thanks !;)
  • Steve Sierra
    May 2, 2017 at 7:42 am
    I think I found what I was doing wrong thanks to this page:
    https://omino.com/pixelblog/2008/12/25/ae-mask-vertices-from-extendscript/
    before the last line, I had to re-inject the vertices in the shape, and then set the value of the shape, not with “=”.
    So the ending should have been :
    modifiedShape.vertices = origVertsM;
    copyShape.setValue(modifiedShape);
    Cheers !
