Activity Forums Adobe Premiere Pro acceptable to edit from a USB 2.0 external hard drive?
  • acceptable to edit from a USB 2.0 external hard drive?
    Posted by Mr Ed on April 12, 2009 at 6:08 am
    How much will this effect my project? I am running with 12 gigs of ram and on windows vista 64. I have over 300 gigs of videos connected to an external hard drive and I just don’t have the space to put them on my drive.
    Will this work or do you advise against it? What will be the downfalls if there are any?
    -Ed
    Vince Becquiot replied 17 years, 5 months ago 4 Members · 5 Replies
  • Jay Noggle
    April 12, 2009 at 6:38 am
    with 12 gigs of ram I don’t think it will be a problem.
    are you saying that the 300 gigs of video are all to be used in a single project? also, is this standard def or hi def?
  • Mr Ed
    April 12, 2009 at 12:21 pm
    Its Standard. Of course I will not be using all 300 gigs but I will be uploading it in the project bin for accessibility.
    thanks
    -Ed
  • Jay Noggle
    April 12, 2009 at 2:37 pm
    Ed:
    For what it’s worth,
    I have been using external drives as low as 4200 RPM for more than 5 years now with no issues other than they are slower so the response and renders take longer.
    As far as that goes, currently I am editing on an Acer Aspire One WinXP netbook and it is amazing. And yes, external drives are part of the workflow there too.
    For best results I have found that putting the source footage on the C Drive is optimum. And then render the final out to the external. Either way, make sure the the Preview renders that Premiere creates go to a different drive than the drive with the source footage.
    Good Luck!
  • Lucas Windsor
    April 12, 2009 at 4:14 pm
    Things will be sluggish when editing video, but you can do it. I have before and I will never do it again, but if you have to do it that way then you have no choice. Your amount of RAM should help a little.
  • Vince Becquiot
    April 13, 2009 at 4:25 am
    The problem with that amount of video is that Premiere will be slow accessing it all. You may experience freezing, etc.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
