Activity Forums Adobe Audition Acapella track question
  • Acapella track question
    Posted by Anthonyv on October 11, 2005 at 2:38 am
    I am planning on doing a project where I take parts of songs to create a new song. In this process, I need to make the original songs acapella so ONLY vocals are heard. Then, I will replace those upon a beat track of my own.
    My question is, how can I effectively and seamlessly extract just vocals out of a song to create an acapella (voice-only) in Adobe Audition 1.5?
    I’ve messed around with the Center Extract in the filters menu, but couldn’t get it to totally drop the instrumental track. I really need it to sound real and as perfect as it can get.
    Thanks for all your help!
    Yvonette France replied 17 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Willie Toth
    October 12, 2005 at 6:36 pm
    Anthony,
    I don’t think you can, or at least I have never been successful using this feature of Audition … There will always be some of the music track left in … The voice dynamic’s change making it sound just this side of ugly … If you are successful please post … WILLIE
  • Anthonyv
    October 12, 2005 at 7:18 pm
    This there, perhaps, a better program I can try? Or a different method?
  • Willie Toth
    October 12, 2005 at 8:05 pm
    Anthony,
    I don’t know of a program that will do it, but at the same time I haven’t had a need to look or use one … I don’t think Audition will do what short of re-record the tracks ………….. WILLIE
  • Rockland
    October 19, 2005 at 5:49 am
    sorry to say this but it’s impossible. the vocal frequency’s are the same as a lot of other instruments like a ..snare drum.. which are generally mixed right in the center along with the vocals.
  • Ozpeter
    October 20, 2005 at 3:43 am
    When you hear this being done on commercial recordings, they have normally had access to the original multitrack material where the voice is on a completely separate track. Audition’s centre channel extractor can produce remarkable results but it’s very dependent on what is in that centre channel along with the voice. Reverberation for instance is likely to be washing around all over the mix.
    Sadly you can’t unbake a mixed cake and get the eggs unbroken out of the mix!
  • Mike Cohen
    November 23, 2005 at 5:47 pm
    I seem to recall my 6th grade music teacher had a record player which did this. Maybe you should contact him if he’s still alive 🙂
    Seriously, he must have had a special record with the vocals only on one channel.
  • Yvonette France
    August 18, 2009 at 11:43 pm
    I found a site with i guess a solution hope it works
    https://www.iterasi.net/openviewer.aspx?sqrlitid=yvvmtdlc_eoen2zkcdzajw
    good luck
    Syren
    https://www.tapegerm.com check out my songs just look me up there
