Activity Forums VEGAS Pro AC3 vs WAV-PCM audio
  • AC3 vs WAV-PCM audio
    Posted by Hollington Lee on August 5, 2005 at 12:38 am
    Hi All-
    Just looking for some advice re: rendering to PCM/WAV or AC3 for my audio when preparing for a DVD. I have so far been using WAV.
    What is/are the reason(s) for using one over the other. My projects are family histories, under 2 hrs — interviews (mono) with photos and sometimes music (buyout library cuts, 44k wav and aiff, rendered to 48k wav).
    Also, re: the 44k to 48k change: is there a downside to changing the sampling rate or should I just use the template default of 44k? The reason I change it is because I read somewhere that DV is 48k and if the audio is 44k, there can be a sync problem. (though I haven’t any any problems with either 44 or 48).
    I’m using V5/DVDA2.
    TIA.
    –Holly
    Gary Kleiner replied 21 years, 1 month ago 2 Members · 1 Reply
  • Gary Kleiner
    August 5, 2005 at 2:09 am
    PCM is higher quality, AC-3 is a much smaller file.
    Stick with the default sampling frequency.
    Gary
