AC3 stereo versus AC3 stereo AGC on
Posted by Michal Bronec on May 26, 2013 at 2:21 pmWhen making a DVD should I use template AC3 “stereo” or “stereo AGC on” when rendering audio stream for DVD Architect?
Michal Bronec replied 13 years, 3 months ago 2 Members · 2 Replies -
Mike Kujbida
May 27, 2013 at 1:07 amI would use the “Stereo DVD” option.
AGC stands for Automatic Gain Control which reduces the volume if the signal is strong and raises it when it is weaker.
I don’t know about you but I don’t want my carefully prepared audio tracks messed with by some auto circuit.FYI, my guess is that you’re using Movie Studio. If I’m mistaken and you’re using Vegas Pro, then you should be using the Dolby Digital AC-3 Pro option as shown below.
If you’re concerned about your audio levels not coming out the way you think they should, modify the preset like so:
Encode set to AC3;
Click on Custom tab;
On the first tab, set Dialog Norm at -31 (this sets it at unity gain);
On the last tab marked Preprocessing, set the Line Mode Profile and RF Mode Profile mode to “none”;
DC High Pass Filter On (this operates at <=3Hz and takes DC bias out of the mix);
Bandwidth Low Pass Filter On (this takes aliasing noise at >20kHz out of the encode).
Save this as a preset. -
Michal Bronec
May 28, 2013 at 12:29 pmI have Vegas Pro 11. I didnt notice there are actually two versions Pro and Studio version. Thanks.
