Activity › Forums › Adobe Premiere Pro › AC3 (Minnetonka) vs. WMV9
  • AC3 (Minnetonka) vs. WMV9
    Posted by Uwe Lansing on October 28, 2006 at 3:01 pm
    Hey there,
    for the Encoding in 5.1 one has 2 possibilities => Mpeg2 with the relatively expensive AC3-Plugin of Minnetonka (Surcode) or free of charge WMV9. Are there big quality differences between both possibilities?
    regards
    Uwe
    Tcindie replied 19 years, 11 months ago 4 Members · 13 Replies
  • 13 Replies
  • Dave Friend
    October 28, 2006 at 5:40 pm
    Is your goal to make 5.1 for DVD? If so, ac3 is the correct choice.
    Dave
  • Uwe Lansing
    October 28, 2006 at 5:51 pm
    Thx Dave, but I only want to know the differences in quality… (some standalones can handle WMV9)
    regards
    Uwe
  • Harm Millaard
    October 28, 2006 at 11:18 pm
    WMV9 AFAIK does not encode to 5.1 sound. Minnetonka is the only way that I know to create 5.1 sound.
    Harm Millaard
  • Uwe Lansing
    October 29, 2006 at 5:21 am
    Ham, it does. If you go under Audio-Codec to the professionel settings
  • Harm Millaard
    October 29, 2006 at 10:20 am
    Thanks Uwe, I did not know that.
    Harm Millaard
  • Dave Friend
    October 29, 2006 at 3:51 pm
    With WM9 it is possible to create/use uncompressed files. AC3 is always compressed to some degree. So if your end-product will support uncompressed that would be better.
    Given WM9 and AC3 files created from the same source material and compressed at the same bitrate I doubt most listeners would notice any difference between them. If someone is able to detect a difference I suspect that which was “better” would be entirely subjective.
    OTOH, WM9 can handle bit-depths and sample rates beyond 16 bits/sample @ 48Khz. Can the Minnetonka encoder do that? I’m not sure.
    Dolby is undoubtedly the more universal format with regards to set-top playback machines. The contrary is probably true if the expected playback platform is a PC.
    Dave
  • Dave Friend
    October 29, 2006 at 3:53 pm
    [Uwe] “some standalones can handle WMV9”
    Can they handle a multi-channel WM9 and properly decode it to 5.1 surround sound?
    (This is not a sarcastic question. I honestly don’t know.)
    Dave
  • Uwe Lansing
    October 29, 2006 at 4:54 pm
    Thank you Dave for your informative posting. Now I already see better through a little bit. I think, with a good DVD player, linked with a HDTV, WMA Pro 5.1 is complete enough. And hardly to distinguish from Minnetonka AC3/5.1…
    regards
    Uwe
  • Uwe Lansing
    October 29, 2006 at 4:59 pm
    There are some devices of different manufacturers like this one:
    https://www.kiss-technology.com/?p=600en
  • Harm Millaard
    October 29, 2006 at 5:11 pm
    I have 4 different brands of standalones (Sony, Panasonic, JVC and Daewoo) and none can handle WMV, all can handle MPEG.
    Harm Millaard
