Activity › Forums › VEGAS Pro › AC3 file? How to create an audio track…
  • AC3 file? How to create an audio track…
    Posted by Jerry Neal on October 26, 2006 at 9:26 pm
    I took all of my AVI video segments (four of them)and placed them on a new timeline. I then selected render as MPEG 2. Once this was finished, I went back to select AC3 for my audio track, but I didn’t see it. I now have my entire video in MPEG 2 but still need to render my audio. I am using Vegas 6 but I don’t see (can’t find) AC3 in the “save as type” menu. Any suggestions as to what I should do would be greatly appreciated.
    Mike Kujbida replied 19 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Don Bloom
    October 26, 2006 at 9:49 pm
    RENDER AS-this will give you AC3 options. You cannot use the SAVE AS command as Vegas doesn’t see AC3 audio only DVDA sees it.
    Don
  • Mike Kujbida
    October 26, 2006 at 9:54 pm
    Do you have DVD Architect?
    You need that to get the AC3 option.
  • Jerry Neal
    October 26, 2006 at 9:59 pm
    Okay, I found the AC3 setting (Render As). However, when I went to use it, I got a promt telling me that I need to purchase the AC3 encoder software. Is this correct? If so, what other options do I have to create a DVD without spending more money on software? I have Vegas 6 with DVD architect 3.0. Thanks for your replies.
  • Mike Kujbida
    October 26, 2006 at 10:45 pm
    Since you have DVD Architect, you already have the AC3 encoder so no purchase is necessary. Have you installed and registered it?
  • Jerry Neal
    October 27, 2006 at 5:20 am
    Thanks for all your help. I’ve got it figured out.
  • Mike Kujbida
    October 27, 2006 at 3:53 pm
    For anyone that may do a search on this problem in the future, would you mind telling us what your solution was? Thanks.
  • Jerry Neal
    October 28, 2006 at 4:43 am
    I had not yet registered DVD Architect. Once I did this, the AC-3 selection worked just fine.
  • Mike Kujbida
    October 28, 2006 at 6:55 am
    Thanks for letting us know 🙂
