Activity Forums VEGAS Pro AC-3 Dialnorm for Hi8 to DVD transfers
  • AC-3 Dialnorm for Hi8 to DVD transfers
    Posted by Jacob Hobbs on August 17, 2007 at 5:05 am
    I’m in the process of converting a lot of Hi8 home movies to DVD. The audio has been captured with peaks up to -3db. So obviously, this is really loud.
    What is the best way of determining the correct Dialnorm value?
    Sound Forge has the “Scan Levels” option for Average RMS Level. Do I select the entire audio file, or just select the parts that have dialogue and take an average value?
    Dialnorm is supposed to be calculated using the average volume of Dialog in a soundtrack. But with home movies that have other stuff mixed with the dialog, this is a difficult decision to determine the correct level.
    What about the Dynamic Range Compression Line Mode options (“Film Light, etc)? Do I enable this too? Previous posts say it only is for “Night Mode” on DVD Players.
    I want all my Hi8 tapes, when transfered to DVD, to have roughly same volume level, so I don’t have to mess with volume control on TV.
    Jacob Hobbs replied 19 years ago 3 Members · 5 Replies
  • Douglas Spotted eagle
    August 17, 2007 at 12:53 pm
    If you’ve already captured the content, I’m not sure why you’re asking about the input levels.
    At -3dB, it is indeed, very hot. Are you looking to overall bring it down prior to encode, or merely wanting to compress it all at playback? For the latter, choose the Speech profile, you might scale back the overall dialog anyway by setting it to -24 vs -27, and choose an RF of speech as well. You’re doing this in Vegas for AC3, not DVD Arch, right?
    Douglas Spotted Eagle
    VASST
    Aerial Camera/Instructor
    Certified Sony Vegas Trainer
  • Jacob Hobbs
    August 18, 2007 at 4:20 am
    Yes, I want to set the dialnorm to bring down the volume, so DVD players can attenuate the volume properly. After setting Dialnorm properly, the reference level on the DVD should be -31db when played back.
    From what I read, Dialnorm value is the average speech level in the audio track. Studios have a seperate audio track for speech, so it is easy for them to get an accurate value.
    My audio is mixed, so I can’t just use the value given from Sound Forge “Scan Levels” function.
    I could set the whole audio track to(-24db or -27db). This will lower it, but this is not correct. It could cause “audio pumping” when used with the Line/RF modes (Film Light, Film Standard, etc…).
    Don’t the Line/RF modes only affect “Midnight mode” on DVD players?
    August 18, 2007 at 4:52 am
    I’m not sure why you’re asking the question if you’re sure of what the outcome will be? If levels are not consistent, then there is no way for the final to be predicted. I don’t use the compression modes, I set my LMP’s to “none” with dialog normalizing at -31 on everything we output. Figure out your average RMS, and that’ll give you the proper normalization level. Regardless, here are the modes/affects.
    None: No dynamic range compression is applied unless downmixing could cause overload, in which case protection [compression] is automatically applied.
    Speech: Appropriate for programs with predominantly dialogue.
    Music Light: Applies light compression to music that is already compressed and does not require excessive dynamic range restriction.
    Music Standard: Applies more compression to music that is not compressed and requires dynamic range restriction.
    Film Light: Applies light compression to a subjectively quiet film that does not require excessive dynamic range restriction.
    Film Standard: Applies more compression to a subjectively loud film that requires dynamic range restriction.”
    These profiles are illustrated below and defined in Appendix A of the Dolby Digital encoder instruction manual which can be found on the Dolby website.
    VASST
  • Valvehead
    August 22, 2007 at 7:02 am
    When discussing dialnorm, the one thing that often gets overlooked is the fact that when the dialnorm level of a soundtrack is measured, it is A-weighted. This means that the midrange of the signal largely determines the proper dialnorm setting. Simply using Sound Forge or Audition to measure the RMS will get you close, but if there is heavy bass content it could give you a number too high.
    Here’s a guide that has helped me understand AC3 encoding a little better: Doom9 AC3 encoding guide. It’s an older guide that refers to Acid, but it appears that the settings are the same in Vegas.
    I think I read somewhere that the idea of normalizing dialog was conceived for digital broadcast. That way the perceived volume would remain consistent across programs and channels. If only something like that had been mandated for radio and CDs. Then there would be no incentive to compress the snot out of it; it would end up getting turned down in the receiver/player.
  • Jacob Hobbs
    August 26, 2007 at 6:04 am
    So if I just set the dialnorm in Vegas to -27db, the output on the DVD should all be set to this level?
    I thought -31db was full volume, which does nothing, so -27db would lower it 4db?
