Activity Forums Adobe After Effects Absorbing Radio Waves – Dynamically
  • Absorbing Radio Waves – Dynamically
    Posted by Tim Tippets on August 16, 2019 at 2:09 pm
    I’ve got an odd one here and I’m hoping someone has some ideas. Here’s the deal.
    I’m using the radio waves effect to express how acoustic absorption works. I setup a square composition and centered the radio waves in the middle. I turned on reflection so the waves are hitting the boundaries of the solid and coming back toward the center, which is great, exactly what I want for step one. Now I want to insert shapes or whatever as acoustic panels on the “walls” of the composition, have the radio waves hit the acoustic panels but be absorbed and not bounce back toward the center of the comp. And those parts of the waves that don’t hit the acoustic panels would still bounce back. Tough, I know. Any ideas and thanks in advance!
    Richard Garabedain replied 7 years ago 3 Members · 3 Replies
  • Walter Soyka
    August 16, 2019 at 2:20 pm
    Maybe you could use Newton for this simulation:
    https://aescripts.com/newton/
    It might be worth trying the demo.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Tim Tippets
    August 16, 2019 at 2:39 pm
    That looks interesting. Can’t hurt to give the trial a shot. Pricey for this one-off, though. Thinking about how I can use it moving forward as well. Thanks!
  • Richard Garabedain
    August 16, 2019 at 3:21 pm
    ..i wish i could see a simple drawing though as im still a bit confused..but if its how I think it is then couldnt you play with the longevity of the waves so that they fade right after bouncing..or maybe you could use vc reflect as your acoustic panels.
