Activity Forums Adobe After Effects Expressions Absolute File Path to Preset FFX
  • Absolute File Path to Preset FFX
    Posted by Dave Currie on June 9, 2018 at 9:38 pm
    I need to get the absolute file path to an AE preset file on Windows and Mac for a script I’m working on.
    This bit of code works on Mac:
    var presetPath = Folder(Folder.appPackage.parent.absoluteURI + "/Presets/MyPreset.ffx");
    var myPreset = File(presetPath);
    However when I run the script on Windows it does not work. I also tried adding “/Support Files” at the beginning of the string but it still doesn’t find the file and the rest of the script doesn’t run. What am I doing wrong here?
    Dave Currie replied 8 years, 3 months ago 2 Members · 4 Replies
  • Andreas Brand
    June 11, 2018 at 2:51 pm
    Changing the slashes to backslashes worked for me on my windows system.
    var presetPath = Folder(Folder.appPackage.parent.absoluteURI + "\Presets\MyPreset.ffx");
  • Dave Currie
    June 12, 2018 at 1:03 am
    Hmm I gave that a try and it still doesn’t want to work. The script creates the layers and doesn’t time out or anything, but it doesn’t apply the preset or any of the expressions I have set.
    I looked at the JavaScript reference here:
    https://estk.aenhancers.com/3%20-%20File%20System%20Access/folder-object.html
    And tried this:
    var presetPath = Folder(appPackage.parent.absoluteURI + "/Support Files/Presets/MyPreset.ffx");
    I put an alert to see the actual file path that’s being retrieved and everything looks correct except for maybe the beginning of the string which looks like this:
    /c/Program Files/…..
    And it still produces the same result 🙁
  • Andreas Brand
    June 12, 2018 at 10:20 am
    Did I understand it right? Do you want to apply a preset with the name myPreset.ffx to a layer?
    I tried this on my windows-machine and with the following code it worked fine.
    Hope it will work on your machine too.
    With an if/else you can ask if the system is os or not.
    var proj = app.project;
    var comp = proj.item(1);
    // Creating a textlayer with the text "Hello World"
    var txtLayer = comp.layers.addText("Hello World");
    //Catching the Preset with the name Schreibmschine.ffx (German wording)
    var myPreset = Folder(Folder.appPackage.parent.absoluteURI + "/Support Files/Presets/Text/Animate In/Schreibmaschine.ffx");
    //Apply the Preset
    txtLayer.applyPreset(myPreset);
  • Dave Currie
    June 13, 2018 at 1:36 am
    You understood correctly, and I finally just got it to work by changing the place where the preset was applied to the layer.
    Thanks for your help Andreas!
