Abso-Noob Questions about the Knife tool
I’m stuck from almost the beginning with this functionality. In attempts to cut rectangular holes in a wall for a door and a picture window I make X & Y cuts all the way across the wall to avoid triangulars and when I go to punch out the material in the hole area, I lose faces on the other side of the wall that need to remain.
Probably has to do with settings for the type of cut I’m trying to do but I’ve searched this forum, the Cafe, and You Tube with ‘0’ results on why this is happening. So far, the subject of settings and the correct procedure to keep what needs to remain isn’t getting covered.
The other issue is 45° cuts for miters. How does one set that value? I tried Edge, Point, and Face mode but drawing from the top corner edge to the inside edge I find that the end point is movable (up & down) so it’s hard to tell where the true 45° angle actually falls out at.
Yup, I need tutes / training and am saving for these but really dislike sitting on my hands whilst waiting.
Most grateful for any direction.
Butch
