Activity › Forums › Test Posting Code Here › Abraham, are you here?
Posted by Jeremy Garchow on November 13, 2013 at 12:47 pmIf so, please respond to my next post (not this original post) as I need to show you something.
Make sure you are subscribed to this thread via email.
Jeremy
Jeremy Garchow replied 12 years, 10 months ago 2 Members · 8 Replies -
Jeremy Garchow
November 13, 2013 at 3:35 pmHi.
I’m going to delete the last few posts, but keep the original.
Note that you will be able to respond to this post, but you won’t see it on the cow, and your response will be deleted as well. Anyone that was subscribed to the thread can respond and get response emails, but the posts themselves are in the ether.
You can see them, however, if you choose to sort the forum by newest posts.
It’s seems a little odd.
Jeremy
Jeremy Garchow
November 13, 2013 at 3:36 pmAnd poof. There are all gone.
This post will show up on the cow.
Abraham Chaffin
November 13, 2013 at 4:45 pmHello Jeremy,
Yes, I am aware of this. Orphaned posts are disconnected from the main thread, this is one of the down sides to allowing users to delete their own posts. The logic is, responses to posts which have been deleted are orphaned because the lineage of responses are no longer connected to the original post and become out of context. However, these individual children posts are still able to be accessed directly, as they may still be pertinent by themselves. Allowing users to delete their own posts, and deactivating posts within threads creates this problem.
I see two possible changes which may help with the confusion, but have negative aspects as well:
1) Automatically deactivate all child posts off of a post which has been deleted or deactivated. This cleans up the issue with orphan posts still showing up in certain views, but may remove helpful content.
2) Remap all orphaned posts onto the ancestor thread. This keeps all posts in the thread even after being orphaned, but the conversation then may be confusing, as posts have been removed from the middle.The mechanism which currently exists, and has existed for many years, is in place because of the drawbacks above.
Jeremy Garchow
November 13, 2013 at 5:58 pmI think that if a post is deleted, it should keep the thread as is, but that post simply says “deleted” by “deleted”.
This keeps the structure in place, does not delete child posts, and I think people will be smart enough to figure out what happened as there’s a but of a “paper trail”.
Does that make sense?
Abraham Chaffin
November 13, 2013 at 9:22 pmThank you for the suggestion Jeremy. You should begin seeing the “Post removed” message around the site now. Hopefully that will solve the issue.
