Activity › Forums › DaVinci Resolve › about Unmix in the Node Graph
Posted by Hisayuki Yamamoto on October 20, 2010 at 7:15 amUnmix features I looked for in the user manual.
But I could not find a straightforward explanation.
Someone please explain what features Unmix.Thank you.
Hisayuki Yamamoto replied 15 years, 10 months ago 2 Members · 2 Replies -
Giles Livesey
October 20, 2010 at 12:07 pmHi Yamamoto San,
If you have an EDL timeline which contains cross fades (edited dissolves) from shot to shot, you would use the Unmix Tab to see your timeline as if it were ‘Cuts only’. This can be useful for match grading directly between shots and seeing the last frame of the outgoing shot compared to the first frame of the incoming shot.
It is mentioned briefly on page 185 of the manual… “Unmix: Unmix is essentially the same as the Clip mode, however no effects such as dissolves or speed changes will be displayed. Note: the Node Graph display above the Dynamics Timeline also displays the Clip, Track, and Unmix tabs synchronized with the Dynamics Timeline.”
Hope that helps,
Giles
https://www.digitalcolorist.com
Hisayuki Yamamoto
October 20, 2010 at 7:10 pmHi Giles
Thanks for the reply.
Unmix EDL functions related to that, I did not notice.
Thanks to give me a straightforward explanation.Hisayuki Yamamoto / Technical Director
https://mount-q.com
Tokyo JAPAN
