Activity › Forums › DaVinci Resolve › about Unmix in the Node Graph
Posted by Hisayuki Yamamoto on October 25, 2010 at 6:16 amIn my Mac Pro to play with DPX clips, dropframe occurs. (about 26fps)
However, I play the RED-R3D footages, dropframe does not occurs.(Continue 30fps)
The RAID storage(FC connected Ciprico) I use with Mac which have a bitrate is 450MByte/sec.Why do dropframe occurs in DPX?
Hisayuki Yamamoto / Technical Director
https://mount-q.com
Tokyo JAPANUli Plank replied 15 years, 11 months ago 3 Members · 7 Replies -
Uli Plank
October 25, 2010 at 8:38 amHow much RAM do you have? Can you play DPX sequences without dropping frames in other programs?
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Hisayuki Yamamoto
October 25, 2010 at 12:27 pmI mistook the title of the thread. I’m sorry.
The correct title is “My DPX files occures dropframes.”My Mac Pro’s RAM is the capacity of 12GB(2GB x 6).
I have not tried other Mac yet.
I try play DPX sequences with djv-0.8.3-pre2.app.Thank you.
https://mount-q.com
Tokyo JAPAN -
Hisayuki Yamamoto
October 26, 2010 at 9:02 amSome verifications were done referring to the last thread.
When I did not succeed by the DPX file, the DPX file made with DaVinci Resolve was used. (DPX RGB 10bit)
I made DPXs by using REDRocket today. I took the DPX files into DaVinci Resolve.
There are no dropframes occureed.Is the DPX files made with DaVinci Resolve special?
https://mount-q.com
Tokyo JAPAN -
Uli Plank
October 26, 2010 at 3:48 pmDo they play with DJV?
Hisayuki Yamamoto
October 26, 2010 at 3:57 pmThe result was the same though I had tried DJV.
https://mount-q.com
Tokyo JAPAN -
Uli Plank
October 28, 2010 at 5:28 pmI’m afraid your RAID is not fast enough, then.
