Activity Forums Apple Final Cut Pro Legacy About the TC reader or generator not going below 01:00:00:00
  • About the TC reader or generator not going below 01:00:00:00
    Posted by Dan Riley on October 20, 2005 at 12:45 am
    I want to put a TC window burn over a segment that starts
    at my sequence time of 59:45:00 and goes to 01;00:30:00.
    Usually the way I do window burns is to nest the seguence
    and put it into a new sequence and drop the TC reader filter on it.
    If I nest the sequence and edit it to a new sequence where I set the
    sequence to start at 59:45:00, the TC reader still says 01:00:00:00.
    Help.
    Dan
    Dan Riley replied 20 years, 11 months ago 2 Members · 2 Replies
  • Michael Buday
    October 20, 2005 at 5:37 am
    The TC Reader is reading the TC of the underlying nest, not the TC of the new sequence. To do what you want:
    – Copy the desired portion of the original sequence and paste it into your new sequence at the desire TC position
    – NEST the copied clips
    – Drop on TC filter on to this nest, and you should be reading the TC of the new sequence
    Michael Buday
  • Dan Riley
    October 20, 2005 at 4:46 pm
    Thanks Michael.
    That did the trick
    Dan
