Activity Forums VEGAS Pro About Sony Vegas project project properties (Audio)
  • About Sony Vegas project project properties (Audio)
    Posted by Levan Katsadze on June 12, 2011 at 6:06 pm
    Please, tell me what is the main diffrence betweeb “Stereo” and “5.1 surround” audio.
    and what is “Number of stereo busses”
    and please, tell me what is diffrence between audio bass and audio buss?
    Danny Hays replied 15 years, 3 months ago 2 Members · 1 Reply
  • Danny Hays
    June 12, 2011 at 10:50 pm
    Stereo is two wave files in one track. 5.1, when Vegas project settings are set to 5.1, and you drop a 5.1 video file on the time line, you get the one video track and three stereo audio tracks, one for front left and right, one for rear left and right and one for center and sub. An audio buss is a track usually used as an effect buss, where you can add a reverb for instance and send any desired amount from any audio tracks to it and it’s output normally goes to the master out. This method is used to get an effect on many tracks with only one effect used. You can use a buss for like a master level for drums for an example. You you could set the output of all the drum tracks to a buss, set all vocal outputs to another, and be able to turn all the drumes up or down with one fadre, same with the vocals. These are audio busses. Audio bass it the low frequency of an audio signal. Hope this helps. Danny Hays
