Activity Forums VEGAS Pro About Sony Vegas Pro project settings
  • About Sony Vegas Pro project settings
    Posted by Levan Katsadze on June 10, 2011 at 8:03 pm
    Please answer to my these several questions:
    1) Which compositing gamma is better quality: 1.000 or 2.222 ?
    2) Which video(MP4) profile is better quality: Main or Baseline ?
    3) Which type of Motion blur is best quality: Gaussian, Pyramid, Box, Gaussian (asymmetric), Pyramid (asymmetric), or Box (asymmetric) ?
    4) What is the main diffrence between these Deinterlace methods: “Blend fields” and “Interpolate” ?
    John Rofrano replied 15 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    June 11, 2011 at 5:33 pm
    [Leo Kac] “1) Which compositing gamma is better quality: 1.000 or 2.222 ?”
    Gamma has nothing to do with quality. It is a measure of luminance. You should use 2.222 unless you have a compelling reason not to.
    [Leo Kac] “2) Which video(MP4) profile is better quality: Main or Baseline ?”
    Profiles and Levels are subsets of the entire MPEG4 standard. Baseline is the minimum that must be supported. Main is the next profile up from Baseline so Main provides more features/quality.
    [Leo Kac] “3) Which type of Motion blur is best quality: Gaussian, Pyramid, Box, Gaussian (asymmetric), Pyramid (asymmetric), or Box (asymmetric) ?”
    Those are all different algorithms for creating a blur. None is “better” than the other. It depends on the look you are after. Most people use Gaussian which is the default.
    [Leo Kac] “4) What is the main diffrence between these Deinterlace methods: “Blend fields” and “Interpolate” ?”
    Blend fields will combine the two interlace fields by blending to make them smoother. It works well with high detail, low motion because it retains full resolution. Interpolate throws half of the fields away. This reduces resolution but is good for high motion where blending still produces undesirable effects.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
