Activity Forums Apple Final Cut Pro Legacy about pulse option when you drag an angle to overwrite box
  • about pulse option when you drag an angle to overwrite box
    Posted by Xavier Casado on June 23, 2009 at 4:54 pm
    I´m reading the book fcp beyond the basics,the part which concern to multicam edit explain that you´ve got to pulse option while you drag the angle to the overwrite box.¿Why?.Which is the difference between drag with f10 or pulse option while put the angle in the overwrite box.
    Thanks a lot
    Jaap Verdenius replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jaap Verdenius
    June 23, 2009 at 6:49 pm
    There is no difference – you just need to press option because if you don’t FCP will switch the active tracks to the angle you are clicking on.
    Jaap
