Activity Forums Adobe Illustrator about Illustrator cs5 clipping masks 2
  • about Illustrator cs5 clipping masks 2
    Posted by Edgar Hudon on June 22, 2012 at 3:06 am
    please read my other post before if you havent
    I wanted to make sure i was clear so ive decided to show the exact problem;
    4323_assis.jpg.zip
    you see the spot of liter red between arms and legs thats what i want to extract from the mask
    thanks again
    Edgar Hudon replied 14 years, 2 months ago 2 Members · 2 Replies
  • Vincent Rosati
    July 3, 2012 at 11:51 pm
    The attached file illustrates a method…
    4354_assisv10.ai.zip
    1
    Make your masks.
    2
    Select the interior components and Object / Arrange / Send to Back.
    3
    Select your front and back vectors and Window / Pathfinder / Minus Back.
    4
    Select everything and Object / Clipping Mask / Make.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Edgar Hudon
    July 4, 2012 at 2:52 am
    thanks a lot lot to have taken the time!
    clear and precise,
    it was simple but i wouldnt have found it on my own
    im so thankful!
