Activity Forums Blackmagic Design About Hyperdeck Shuttle
  • About Hyperdeck Shuttle
    Posted by Ahmed Sajid on December 20, 2011 at 12:43 pm
    I hope this is the right place to ask.
    I am about to order a Hyperdeck shuttle, to do a greenscreen recording on the Sony F3. I just wanted to confirm a few things,
    1. Will I be able to use it as an HD-Sdi to HDMI converter, so that i can run an HDMI feed from the HS, to a monitor, even when its not recording ?
    2. Is there a loop-out function on Sdi, so I can get another feed to go on to a waveform monitor ?
    3. What wrapper does it use for uncompressed 422 files ? I am guessing a .mov , would like to confirm anyway.
    Thank you in advance.
    Kristian Lam replied 14 years, 8 months ago 2 Members · 1 Reply
  • Kristian Lam
    December 20, 2011 at 9:44 pm
    [Ahmed Sajid] “1. Will I be able to use it as an HD-Sdi to HDMI converter, so that i can run an HDMI feed from the HS, to a monitor, even when its not recording ?
    Yes, you can. You can even use it as a battery powered converter when when you don’t have an SSD inserted.
    Yes, all outputs as active.
    3. What wrapper does it use for uncompressed 422 files ? I am guessing a .mov , would like to confirm anyway.”
    You’re correct. It’s a Quicktime compatible .mov file.
    regards
    Kristian Lam
    Blackmagic Design
