Activity › Forums › Apple Final Cut Pro Legacy › About Fxplug SDK
  • About Fxplug SDK
    Posted by Sangwoo Kim on March 19, 2008 at 12:56 am
    Hello,
    I got few question for FxPlug SDK.
    I posted the same question about Adobe Premiere.
    Anyway,
    1. Actually, I hava a CMS(Content management system) and I want a connection between CMS and FCP.
    It means that I want to update some information related to the video through the FCP.
    Is it possible senario through the FxPlug?
    If it’s possible, which part do I need to look in FxPlug?
    2. Also, is there any plug-ins which have functions like Character Generators?
    Niclas Bahn replied 18 years, 6 months ago 4 Members · 4 Replies
  • Peter Wiggins
    March 19, 2008 at 8:30 am
    What do you want to import into FCP? Images, data?
    This can already be done using plugins, just need a bit more info from you.
    Peter
  • Sangwoo Kim
    March 19, 2008 at 8:53 am
    Actually, I want to get some data from CMS when I import video files.
    Sangwoo,
  • Andy Mees
    March 19, 2008 at 9:36 am
    Sangwoo,
    I think your questions would be better directed to the proapps developers list
    mailto: pro-apps-dev@lists.apple.com
    https://lists.apple.com/mailman/listinfo/pro-apps-dev
    Cheers
    Andy
  • Niclas Bahn
    March 19, 2008 at 11:59 am
    Have a look at FxFactory Pro.
    You can load images and data into quartz compositions in real time, which are then packaged into fully functional FxPlug plug-ins that run in FCP/Motion and Final Cut Express. You can generate characters, text etc.
    If you need to read data from a database, an easy way to get it into a plug-in is via an rss feed. You can have a look at RSS World News plug-in as an example. It is in the NI Generators category.
    Regards,
    Niclas
    Noise Industries
    https://www.noiseindustries.com
