Activity › Forums › Apple Final Cut Pro Legacy › abbreviated list under “RT” pop-up menu
  • abbreviated list under “RT” pop-up menu
    Posted by Bob Cole on May 7, 2010 at 7:02 pm
    I’m experimenting with a new camera which creates MP4 files, and something happened which I’ve never seen.
    The RT pop-up menu (in the sequence window, on the upper left) has been truncated to just four lines.
    1. Play Base Layer Only
    2. Record to Tape (grayed out)
    3. Use Playback Settings
    4. Full Quality
    Oddly, the first time I imported files from the new camera, the sequence had its usual 18 lines. Otherwise I’d suspect a codec issue – still do actually.
    Ideas?
    Bob C
    Kevin Monahan replied 16 years, 4 months ago 2 Members · 1 Reply
