A/B Roll Editing mode in Vegas Pro 12
Posted by Bruce Miller on July 12, 2013 at 2:02 pmI have seen this answered in other places, but no luck. I stumbled into A/B Roll editing mode (video track split into two) and I can’t reset to normal. Presumably NumKey 5 or clicking the edge of an event should revert it back. All I get from that is toggling visibility of trimmed footage (grayed out).
Bruce
Kent Frost replied 11 years, 9 months ago 6 Members · 8 Replies -
Roger Bansemer
July 12, 2013 at 2:16 pmI don’t like that A/B mode. I’m always hitting some unknown key be accident and making it appear.
Supposedly the #5 key is works but just try the escape key.Roger Bansemer – PaintingAndTravel.com
Graham Bernard
July 12, 2013 at 2:46 pmI agree with Roger.
G
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Bruce Miller
July 12, 2013 at 2:50 pmI ended up moving the clips to a fresh track and deleting the offending AB video track.
Definitely something buggy.
Bruce -
Norman Black
July 12, 2013 at 2:59 pmRight click in the track header and choose, Expand track layers.
If not expanded it will expand.
If already expanded, a check mark will be on the menu item and selecting will collapse the layers.The numeric 5 key, event edge and such are used with expanded edit mode in and out.
Bruce Miller
July 12, 2013 at 3:06 pmThanks. This is now the only place on the Internet where this secret information resides.
Bruce
Stephen Mann
July 12, 2013 at 3:33 pmI know of no one who uses the AB mode – I suspect it’s there to give a familiar UI to editors moving from ancient platforms.
Entering and reversing the mode are explained in the help file, but the step you may have missed is to select an event first. It may be a bug but after entering the expanded A-B mode, one of the events is highlighted as if it’s selected, but you need to click on it again to select it.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Norman Black
July 12, 2013 at 6:01 pm[Bruce Miller] “hanks. This is now the only place on the Internet where this secret information resides.”
My info came from the Vegas help file.
Bring up the help file.
In the index tab enter, A/B.
You now have a list of topics. The first one talks about A/B roll editing (track layers).
Open that help topic, and expand the track layers item.
The info is there.I have “enabled” things in the past by accidentally hitting some keyboard shortcut I don’t know about. Fat fingering as I call it.
I searched the keyboard shortcut help page and did not find anything with a quick cursory search. I searched that help page for layer, A/B, expand, collapse.As a new Vegas user I have found that the help file is pretty complete but not always easy to find info as the terminology I used in a search was not the exact term Vegas used.
Kent Frost
December 27, 2014 at 4:55 amReal easy to way to get both in and out of A/B mode (which is why it’s so easy to find yourself there in the first place):
Double click the left edge of your clip in the timeline. That’ll put you into A/B. Don’t want that? Double click it again. Boom.
