Activity Forums VEGAS Pro AAV ColorLab v1.0b3 (formerly 6cc)
  • AAV ColorLab v1.0b3 (formerly 6cc)
    Posted by Carl Adahl on August 31, 2008 at 6:42 pm
    I won’t be doing this continuously, but I’m pleased to announce a name change and some major changes in the “Aav’s 6cc” plugin.
    Like before, it does six-vector color correction (still missing out of the box in Vegas). It now exploits the raw power found in modern graphics cards, giving you much faster renders and previews than previous versions.
    ColorLab is intended to be a more complete “toolbox” of effects, all using the GPU. In this version, the following are included:
    – 6-vector c.c.
    – Levels
    – Brightness & Contrast
    – Black & White
    Bonus AAV TransLab transitions:
    – Fade
    – Additive and Subtractive dissolves
    It’s still free, but appeals to your conscience by being “donationware”. 🙂
    Get it here: https://aav6cc.blogspot.com
    Carl Adahl replied 17 years, 12 months ago 6 Members · 11 Replies
  • 11 Replies
  • Steve Rhoden
    August 31, 2008 at 11:44 pm
    Continue the great work Carl….Thanks.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • Terry Esslinger
    September 1, 2008 at 2:25 am
    Carl,
    When I try to apply the CC I get no control window and the preview window turns solid red. Pr8b. What might I be doing wrong?
  • Carl Adahl
    September 1, 2008 at 6:26 am
    8.0b is what I’m using too.
    Did you get any errors when installing it? Remember to uninstall Aav6cc beta 1 or 2 if you tried that earlier.
    Otherwise, could you look up the following in either Explorer or Internet Explorer?
    file://%APPDATA%/AAV ColorLab/log.txt
    If that doesn’t give you anything, try %APPDATA%\AAV ColorLab\log.txt
    Post the text back here please.
  • Leslie Wand
    September 1, 2008 at 10:09 am
    as i emailed you, i’m simply getting the fx choice box coming up when i drop it on a clip and no adjustment window for it…
    leslie
  • Carl Adahl
    September 1, 2008 at 4:50 pm
    There may be a problem with the installer. I’ve switched to a different installer for beta 4, and this should ensure the dependencies are satisfied.
    Another possibility is that you don’t have a “DirectX 9” graphics card (with shader model 2.0 support). There is currently limited error checking in the plugin, and I’m trying to fix this for beta 4 also.
    I’ll post again when I’ve released it. Thanks for trying ColorLab, all feedback is appreciated.
    If you’d like to try installing the dependencies manually, please grab these:
    – DirectX 9.0c (https://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en)
    – .NET Framework 2.0 (https://www.microsoft.com/downloads/details.aspx?familyid=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en)
  • John Frey
    September 1, 2008 at 5:35 pm
    Installer stops just before the end saying, “cannot find Netframe” even though it is already installed.
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
  • Harold Brown
    September 6, 2008 at 3:47 pm
    Hi, Carl
    If I install beta3 will my old veg files fail to work because of the missing aav6cc plug-in?
    Harold
    __________________
    http://www.BhagaVideo.com
    Check out my published DVDs at
    http://www.edellismagic.com/Previews.html
  • Terry Esslinger
    September 19, 2008 at 5:22 am
    Cannot get AAV Colorlab to work.
    It appeared to install ok. I choose media Fx and it is listed in the Fxs. I choose it and apply it to the event but the Fx control box stays blank. There is nothing in it. What have I done wrong?
    Here is some information that might be useful:
    [05:16:14] [INFO] D3DThread: Created D3D device 76047552 in 1848
    [05:16:14] [INFO] D3DThread: Device: \\.\DISPLAY1 RADEON X300/X550 Series
    [05:16:14] [INFO] D3DThread: Driver: ati2dvag.dll (6.14.10.6727) WQHL Certified (no date)
    [05:16:14] [INFO] D3DThread: Device created in thread 1848
    [05:16:14] [INFO] GPU9: Adjusted dimensions: 720, 480
    [05:16:14] [INFO] GPU9: (Re)creating buffers 3x(720×480)
  • Leslie Wand
    September 19, 2008 at 6:16 am
    download 1.0b4
    had the same problem – fixed now.
    on ya carl!!!
    leslie
  • Carl Adahl
    September 19, 2008 at 5:44 pm
    Hi John,
    Is this with beta 4?
