Activity Forums Avid Media Composer AAF Questions !
  • Michael Phillips
    January 22, 2015 at 2:43 pm
    The easiest method is to import into MC… 😉
    Other than that, there is a method I used on Windows to create a .txt file of the AAF. While most of it is readable, there are still codes and stuff for the effects that one needs to know how to parse via the AAF toolkit. You also need to do some math and offset counting for START and END, etc.
    Michael
