Activity Forums DaVinci Resolve AAF interpretation support from avid
  • AAF interpretation support from avid
    Posted by Manuel Augustus on June 26, 2024 at 12:32 pm
    Good morning
    I would like to ask you a question about Davinci’s conforming of clips with a retime or resize from an AAF created by Avid.
    We have often encountered errors in the interpretation of retime or resize and we are forced to re-form the individual clips by hand.
    Is there a system to make Davinci’s retime (or resizes) of clips provided by an AAF created by an Avid edited one interpret well?
    Thank you very much.
    Glenn Sakatch replied 2 years, 1 month ago 2 Members · 1 Reply
  • Glenn Sakatch
    July 11, 2024 at 12:32 am
    I think it comes down to how the effect is built in Avid. If the editor is using the motion effect editor, thise should come across into Resolve. It is possible some if the older time warp tools don’t work. (Trim to fill comes to mind…might not translate).
    For resizes, same thing. If they are putting the effect on the track above the clip, i dont think that will work, but a basic 3d warp effect should come across easily, as long as you turn on (use sizing information) when you bring in the list.
    I’m not sure if resize or Pic in pic come across. I would just try as many different methods for both that you can find, and see which ones work. I rarely have issues.
