Activity › Forums › DaVinci Resolve › AAF fails to import
  • AAF fails to import
    Posted by Roman Hankewycz on July 29, 2011 at 9:32 pm
    Hello,
    I’m doing some tests bringing in AVID AAF’s into Resolve to work with some XDCamEX footage. But I can’t even get the AAF to create a session. I’m including a screenshot of the dialogue box that appears after I try importing.
    Does anyone have any insight? Are there any settings that the editor should be aware of when exporting the AAF?
    roman hankewycz
    harbor film company // colorist
    Roman Hankewycz replied 15 years, 2 months ago 2 Members · 2 Replies
  • Michael Phillips
    July 31, 2011 at 1:00 am
    It is basically indicating that not all the effects are supported between Avid Media Composer and DaVinci Resolve. This is the first implementation of AAF, I am sure that over time, additional effects will be supported. Plug-ins are a different matter as they would also need to be supported within Resolve to properly interpret.
    Michael
    Michael Phillips
  • Roman Hankewycz
    August 1, 2011 at 3:30 am
    OK, but are the effects and plug-ins preventing the sequence from coming through? Like I said, after I close that “error log” window nothing happens. Should I tell the editor to remove all effects from the sequence before exporting an AAF?
    roman hankewycz
