Activity Forums DaVinci Resolve AAF Conform Problems
  • AAF Conform Problems
    Posted by Swen Linde on September 26, 2012 at 10:32 am
    Hi all,
    we are in big trouble opening aaf Files from Avid Medicomposer 6.0 in Resolve 9.0.
    Nearly 90% of the shots are not recognized. The AAF is exported with no media inside.
    The following message appears after trying to link to the imported Alexa QT ProRes 4444 Files.
    “Non-File SourceMob is detected and ignored”.
    EDL Conform of the same Sequence works fine.
    Has anybody expirience with this issue.
    I also tried this aaf in Scratch which worked fine.
    Thanks for your help.
    Best Regards.
    Swen
    Craig Harris replied 13 years, 12 months ago 3 Members · 6 Replies
  • Craig Harris
    September 26, 2012 at 5:34 pm
    Hello there,
    You need to commit all multi-cam edits in AVID before you export the AAF.
    Craig
  • Craig Harris
    September 26, 2012 at 5:47 pm
    How is Resolve set up for reading your Reel IDs?
    What is your source footage?
  • Swen Linde
    September 27, 2012 at 12:23 pm
    Thanks Craig, for oyur quick response.
    The Footage is Alexa Log-C and the Reel ID will be taken from the embedded one in the Source Clip. I will check if the Multi Cams are committed.
    Swen
  • Rohit Gupta
    September 27, 2012 at 1:16 pm
    Can you send us the AAF at davincihelp (at) blackmagicdesign.com?
    Rohit
  • Swen Linde
    September 27, 2012 at 1:48 pm
    Hi Rohit hi Craig,
    the aaf is working now. The editorial did not commit the multicams and I forgot to check this. Thanks Craig. Rohit i will send the aaf to the davinci support. It´s conforming but has a lot of error messages as mentioned before. “Non-File SourceMob is detected and ignored”.
    It will be interessting to hear what this is saying us.
    With best regards
    Swen
  • Craig Harris
    September 27, 2012 at 8:49 pm
    DaVinci won’t read all the AVID effects. That is probably why you are getting the error messages.
    Craig
