AAE Won’t Import Scripts (*.jsx files)
Hey guys,
So basically, I wanted to learn about scripting in AE.
After playing around, I decided to take a go and start the tutorial. Sadly enough, I’m stuck on the first step:
“You should save your text with the Unicode (UFT-8) option.” […] “To run the script, (don’t forget to create a comp first), just go to the File menu, select “Run Script”, then select “Choose File…” (assuming you haven’t stored it in the “Scripts” folder). Then navigate to wherever you saved your script and open it.”
Thing is, even if I copied/pasted the “expression” in Notepad and saved it as Unicode (UFT-8), it doesn’t appear. I go to Files > Run Script > Choose File > AAE Scripts (where I saved it) and, there’s no script at all. If I click on “All Acceptable Files” and I click on the Notepad file, it’ll do nothing.
Am I doing something wrong? Is there a basic program where I can save those expressions in a “*.jsx” format?
Thanks for your time guys.
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional
