Activity Forums Adobe After Effects AAE CS6 Analysis solved failed error off the screen?
  • AAE CS6 Analysis solved failed error off the screen?
    Posted by Tomi N. on February 2, 2013 at 1:42 pm
    In some points my AAE says “Analysis solve failed.” and “Unable to create camera for this frame.” when i do Track camera. It’s normal I quess since those are some dark parts on video.
    But problem is when I wanna render the clip those red error texts are still on screen and they appear on finished render video.
    How I get them off?
    Than you in advance.
    Arjen Jongeling replied 10 years, 1 month ago 6 Members · 5 Replies
  • Michael Zoppo
    February 26, 2013 at 7:21 pm
    The very last line under the advanced setting in 3d Camer tracker is Hide warning banner, click that so it’s checked and it will remove the warning from your final render.
  • Ryan Hill
    April 16, 2013 at 9:58 pm
    That check mark does not hide the “Analysis solve failed” banner.
    It hides every *other* type of banner, but not the Analysis solve failed banner.
    So if you want to, for example, render the 2D Source trackpoints, you’ve got a big red “Analysis solve failed” banner slapped across them.
    Anyone have any ideas?
  • Jacob Stærk
    April 26, 2013 at 8:57 pm
    It was a little silly but I got rid of the sign but deleting the video from the composition window and then I dragging and dropping the video back in from the project window…
    Good luck,
    Jacob
  • Adam Kosh
    October 28, 2013 at 3:50 pm
    Hello Ryan,
    Did you find a solution for your problem? The same thing happens here…
  • Arjen Jongeling
    July 21, 2016 at 2:42 pm
    When you press Track Camera under Tracker, it creates an effect called “3D Camera Tracker” under Effect Controls. If you delete the effect, the error message goes away.
