Activity Forums Compression Techniques AAC-Low Delay decoding issue
  • AAC-Low Delay decoding issue
    Posted by Thushan Amarasiriwardena on March 15, 2011 at 9:41 pm
    Howdy,
    I’m having an issue decoding AAC-LD (Low Delay) files using a recent build of FFmpeg. Every time I try to decode it I get the issue: “Audio object type 23 is not supported”
    This audio file is coming off an iPad using the built in compressor. Has anyone else had these issues? The file plays fine in QuickTime.
    Many thanks,
    -Thushan
    ffmpeg -i 96ECEBBC-EBDC-43C7-90DE-01FCB7B0240B.m4a -ac 1 -ar 44100 96ECEBBC-EBDC-43C7-90DE-01FCB7B0240B.mp3
    FFmpeg version SVN-r24986, Copyright (c) 2000-2010 the FFmpeg developers
    built on Mar 14 2011 11:21:48 with gcc 4.4.3
    configuration: –enable-gpl –enable-nonfree –enable-pthreads –enable-libx264 –enable-libfaac –enable-libmp3lame
    libavutil 50.24. 0 / 50.24. 0
    libavcore 0. 6. 0 / 0. 6. 0
    libavcodec 52.87. 0 / 52.87. 0
    libavformat 52.78. 3 / 52.78. 3
    libavdevice 52. 2. 1 / 52. 2. 1
    libavfilter 1.38. 1 / 1.38. 1
    libswscale 0.11. 0 / 0.11. 0
    [aac @ 0x1ea4930] Audio object type 23 is not supported.
    Last message repeated 433 times
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x1ea3470] max_analyze_duration reached
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ’96ECEBBC-EBDC-43C7-90DE-01FCB7B0240B.m4a’:
    Metadata:
    major_brand : M4A
    minor_version : 0
    compatible_brands: M4A mp42isom
    Duration: 00:00:30.75, start: 0.000000, bitrate: 93 kb/s
    Stream #0.0(eng): Audio: aac, 0 channels, 65 kb/s
    96ECEBBC-EBDC-43C7-90DE-01FCB7B0240B.mp3: Permission denied
    Thushan Amarasiriwardena replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
