Activity Forums Maxon Cinema 4D AA settings that work for animation??
  • AA settings that work for animation??
    Posted by David Martin on June 12, 2008 at 1:40 am
    SOS. I’m new to C4D but not 3D animation.
    I created a simple scene with GI. It flickers on animating. AA set to “Best” I tried combinations of Threshold, min/max and MIP scale in the render settings, to no avail. Ergo, I have one question that ALL animators need answering: what are settings that do not flicker? I don’t care about render time, as flicker is a show-stopper.
    Any advice gratefully received.
    regards, David
    Brian Jones replied 18 years, 3 months ago 3 Members · 5 Replies
  • Brian Jones
    June 12, 2008 at 4:05 am
    Do you have the AA Filter set to Animation?
  • David Martin
    June 12, 2008 at 12:11 pm
    Yes, filter set to animation.
  • Donal Hanafin
    June 12, 2008 at 1:16 pm
    It might be your gi settings. if you set it to stochastic then it’ll stop flickering but prepare for longer render times. Or else buy vray, it’s way better than the cinema 4d renderer http://www.vrayforc4d.com
  • David Martin
    June 12, 2008 at 1:32 pm
    donal,
    Wonderful! Thanks for tip. I’ll look at VRAY.
    Again, many thanks.
    regards
    David
  • Brian Jones
    June 13, 2008 at 1:34 am
    GI – oh right (sleep is good), check out Help for GI there are two animation modes for GI, Camera and Object and the descriptions there should help about which you would want to try.
