Activity Forums Adobe After Effects A weird but (hopefully) simple problem: AE will not accept my color changes…
  • A weird but (hopefully) simple problem: AE will not accept my color changes…
    Posted by Jesse Clark on March 13, 2015 at 12:11 pm
    Hello all,
    This is sort of a weird issue, and probably incredibly simple, but I don’t know what i’m doing wrong here…
    I’m using AE 5.5, and I loaded up a project of mine from a few months ago…
    In the project I have a number of pre-comps, and they are set up so that all of the small assets and details can be easily color-swapped. However, for some reason, whenever I try to change the color on ANY of my assets, it refuses the change…
    For example, I select the color palette, choose my new color, click OK, and then… for some reason, it ignores my choice and instantly reverts back to the original color (the one I saved it as the last time I used my assets a number of months ago…)
    And again, it does this for EVERY asset in the project file.
    Does anyone have a clue as to what it may be? :/
    I’ll include a very crude, simple image of what is happening, if it helps.
    Thanks again.
    John Cuevas replied 11 years, 6 months ago 2 Members · 2 Replies
  • Jesse Clark
    March 13, 2015 at 8:35 pm
    Thanks for the reply, Dave
    Apologies for the late response, have been at work;
    Changing the effects stacking order did nothing. Unfortunately, neither did changing the color of the black solid that the effects are applied to.
    Something odd I’ve noticed…
    If I set the color to something else, say, green for example… as I explained, it instantly reverts the color back to the blue.
    But, if I re-open the color selection tool, the palette is still set to the green I had chosen before.
    ALSO, oddly worth noting… if I set it to a different color, and then click and drag the opacity slider… the “color” box temporarily turns green as i’m sliding the slider… once I release the slider, however, the color box goes back to being blue. (this doesn’t affect the actual Solid in any way, just the effect control’s color box…)
  • John Cuevas
    March 14, 2015 at 11:16 pm
    Could you upload just the procomp(last icon in reply dialogue) and I’ll take a look at the issue.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
