A way to change image dimensions without affecting puppet pins?
Hi all,
so I made a huge mistake that I am now paying for. I know better, but alas, I tested the gods. I have a creature that I painted in Photoshop and cut up for After Effects. Right now there’s not a lot of room between the creature’s horns, and the edge of the canvas in Pshop. My client wants the monster’s head to do some pretty extreme scaling, so when I do that, the creature’s horns are getting cut off.
The problem is, I already used the puppet tool on the head. If I try and move the head down in the original psd, it will not move the puppet pins along with the head. This means my puppet tool mesh is essentially useless and I have to redo the rig and start over.
Is there any way to adjust the size of an image’s canvas without destroying a puppet tool mesh? Any help would be vastly appreciated! Thank you all!
